configure log target memory-buffer alert percent-full
configure log target memory-buffer alert percent-full [ percent | none ]
Description
This command configures the log buffer threshold alert.
Syntax Description
percent-full Generate a log event when the memory buffer percentage fully exceeds the specified percentage threshold.
percent Percent-full threshold to generate a log event [50-100].
none No alert.
Default
None.
Usage Guidelines
Use this command to configure the log buffer threshold alert.
This command was first available in ExtremeXOS 16.1.
Platform Availability
